First post, by vetz
I'm currently building a new 386DX system with some nice parts (SCSI, Et4000AX, 8MB RAM, Soundblaster). Sound can be a very tricky descision, and I'm in doubt what to install in it.
Potential sound cards:
Soundblaster 2.0 (CMS chips I can aquire)
Soundblaster Pro 2 (CT1600)
Leaning most towards the Pro 2 here.
My main question is to install the Midiman MM-401 card in my 386 or keep it in my 486? Are there any games that require an intelligent MIDI interface card for the MT32 (or CM32L that I have) that benefit from a 486 CPU?
If you think that the card would benefit more being in the 386, then I'll just have the Roland CM500 connected to the Soundblaster MIDI port on my 486. Giving the option to switch to LA synth in some odd game or two.
Reply 1 of 9, by robertmo
you could even ask if you need mt32 for 486 at all 😉
or are there any sound canvas/gm games that use intelligent mode 😉
Reply 2 of 9, by keropi
you have too many LA devices vetz and I have too few 🤣
on topic though, I can't remember any game that *needs* a LA synth and requires a cpu better than a 386... usually stuff that benefit from a 486 support also GM or GS...
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 3 of 9, by Jolaes76
There is a certain speed and responsiveness advantage with the 486 but there arent many arcades / sims which need the 486 CPU for smooth running. Late DOS-era "backport" patches for Comanche and Ultima games come to mind, also X-Wing... - games which were written for general MIDI in the first place. But as far as I know, intelligent mode is not required for these.
I myself keep the LAPC-I in a K6-3+ rig for now but only because it has the most reliable PSU.
"Ita in vita ut in lusu alae pessima iactura arte corrigenda est."
Reply 4 of 9, by vetz
Yeah, that was what I thought.
I guess later games (for the 486) that do support the MT32 do not need intelligent mode and will be just fine running from UART. The card is going into my 386 then 😀 Now I just need to find a case for it! heh, easier said than done! Getting the case might turn out harder than all the other parts combined....
keropi: I only have two LA devices at the moment (CM32L and CM500), so I'm not like Mau1wulf1977 or some other members here on Vogons 🤣.
Reply 5 of 9, by Mau1wurf1977
I also agree 😀
If we look at specific games we can see that Wing Commander 1 and 2 supported the MT-32 but Strike Commander and Privateer already had General MIDI support. Same goes for Sierra (Space Quest 3 and 4 MT-32, Space Quest 5 General MIDI) and Lucasarts (Monkey Island 2 and Fate of Atlantis MT-32, DOTT and Sam & Max General MIDI).
My YouTube channel
Reply 6 of 9, by bjt
Would be interested to know whether the games you mention (Strike Commander, Privateer, SQ5) were intended primarily for MT-32 or GM. Pretty sure Privateer was composed on GM as it sounds great on the XR385.
Reply 9 of 9, by Malik
I'm running a MPU-401 "intelligent" card - MusicQuest PC MIDI card in my Pentium II 400MHz machine. I just set the 8-bit I/O Recovery Time in BIOS to 8, to avoid speed related issues. Unfortunately, not all motherboard BIOS has this option. It is currently connected to the CM-500.
I still play Heart of China - just for the music actually, in this setup. (I don't play the arcade sequence with this setup. I just click to win the sequence.) GODS' CM-32L specific banks are played accurately. DOS running speed is at 400MHz.
I don't have a 386, but my 486DX2-66 currently runs with the LAPC-I. I just set the Turbo Button to off to play early Sierra games. The games play well and the LA synth works as it should, and I don't think there will be requirement differences in using a 386 or 486 for this purpose. If I still needed to slow this 486 for gameplay reasons, I set the internal cache to off, using ICD.EXE. When it comes to LA synth, it is not affected at any speed in this 486.
Playing with internal cache and the turbo button, I can create a spectrum of system speed from a 2.9MHz and 8MHz PC XT like system, to a ~25MHz 386DX-like system upto the max 66MHz 486. More info : The 486, The Turbo Button And The Internal Cache - Rudimentary Speed Analysis
EDIT : The system specs will vary since they are written at different times, but focus on specific issues.
EDIT2 : All the above systems use a PSU with the -5v rail.
