First post, by LChackr
- Newbie
Hi all.
I recently built a "new" retro rig and am having some problems booting from Compact Flash. The system board is an Intel MS440GX with a single PIII Xeon (550MHz) processor card installed. I have tried multiple CF cards and type in an IDE2CF adapter in the primary ATA port. The Intel BIOS detects it and correctly identifies the size of each card but I just can't get it to start the boot process.
A bit more information:
- I've tried multiple CF cards, including a Transcend Industrial True IDE (Fixed Disk Mode) card.
- A Linux boot CD detects the "drive" with no problem and will let me partition them and copy data to them.
- Windows XP setup detects the cards as a hard drives and will partition them and install XP with no problem.
- If I use a DOS boot disk (6.22) it does NOT detect the card. The CF "read" light on the adapter lights up for a few seconds then goes off. The same thing happens when I try to boot on the card.
- I have also tried booting from a ATA PCI card. If I put the adapter in that card the Promise BIOS detects the card, correct DMA mode and size. Still, no boot.
Does anyone have any ideas? This is very frustrating.
Thanks!
