First post, by emendelson
This is a question for Dominus and anyone else who works with DOSBox under OS X.
I've begun to try to add a Services menu to the DOSBox menu, to make it possible to run an OS X service with a hotkey, or from the Services menu, while DOSBox has the focus.
I think I've figured out the basics (adding items to the info.plist file), but before I go to work on it, I wonder if anyone has already done the work and would be willing to share their results.
Whatever happens, if I manage to add a Services menu to DOSBox for OS X, I'll post the method here. Thanks in advance for any help.
