First post, by feipoa
Does anyone have any framerate comparisons for identical hardware in Win98SE vs. Win95 OSR2.x for 486 through Pentium 133 systems? I am wondering if the bloat of Win98SE cuts in to framerates at all.
Reply 2 of 12, by feipoa
vetz wrote:
Ive used both on my retro machines. Never noticed any difference in games. Win98SE requires more RAM to run smoothly so it is possible there is a difference on systems with less RAM
Did you test GL Quake and Quake 2?
Reply 4 of 12, by Putas
Depending on the setup there will be negligible gain or loss. I would not dare to pass general judgement.
Reply 5 of 12, by d1stortion
95 vs. NT4 or 98SE vs. 2K would be a lot more interesting. Maybe with P6 instead of 486 😀
Reply 6 of 12, by idspispopd
95 vs NT4 would be limited because of missing Direct3D acceleration in NT.
In 2K (and XP) gaming performance was at first worse than in 9x until the video chip companies managed to optimize their drivers. I think that happened only months after the release of XP, possibly 1-2 years. According to http://www.oocities.org/ziyadhosein/rprow2k.htm it never happened for ATI Rage Pro. (There are no 3D accelerated drivers for 2k/XP for most other early 3D accelerators.)
Reply 7 of 12, by d1stortion
Yeah I was thinking about WinQuake for NT4 to make it independent of 3D card. The difference for Q3 is just a few frames: http://www.tomshardware.com/reviews/athlon-kx … dup,186-15.html & http://www.tomshardware.com/reviews/athlon-kx … dup,186-18.html
For 2K I've read that the latest 3dfx drivers fixed the performance disadvantage.
Reply 8 of 12, by Jorpho
There's the 98lite performance comparison at http://www.litepc.com/perform.html . That's sort of like 95 vs 98.
Reply 9 of 12, by feipoa
Quake II jumped an average of 0.5 fps, from 12.5 fps to 13 fps.
Reply 10 of 12, by Logistics
It's been too long since I've used 95 or 98 to remember if they use ACPI, but in XP I get a significant performance increase (ie franerate increase, responsiveness) with ACPI disabled.
Reply 11 of 12, by mr_bigmouth_502
Disabling ACPI with Win98 is a good idea anyway, since it sometimes has problems shutting down with ACPI enabled.
Reply 12 of 12, by feipoa
I suppose if anybody does any benchmarks on this topic, it would be just as interesting to extend the platforms to include Win95 a/b/c, Win98, Win98SE, WinME, NT4, W2K, and XP.
