First post, by rgart
Hey
I recently found a Compaq Proliant 850R webserver gathering dust.
CPU: Dual Pentium Pro 200mhz
Memory :512 MB
Operating System: Windows NT Server 4.0
Optical Drive CD-ROM - SCSI
Hard Disk - SCSI
Graphics Processor CL-GD54M30 (cirrus logic on board)
Cache Type L2 cache - Write-Back
I cant imagine it has a practical use for gaming and I probably need to use NT Server or Windows 2000 to get both CPU's recognized and used.
Any recommendations on upgrades/gaming uses? I guess what i am asking is what possible uses does it have?
Reply 1 of 20, by swaaye
Small room heater. 😀
Reply 2 of 20, by mwdmeyer
It would be a good heater 😀
There aren't many games that use SMP that work on such an old machine.
Reply 3 of 20, by luckybob
+1 for noisy space heater.
aftermarket is the only way to go with Pentium Pro. Personally, I love the platform. Are your chips 512kb or 256k cache?
Reply 4 of 20, by Unknown_K
They made 1MB cache ones also.
Reply 5 of 20, by rgart
256k cache on each cpu
Reply 6 of 20, by rgart
aren't many....which ones do?
Reply 7 of 20, by luckybob
scrap it for gold. Its common for each pentium pro chip to grab $50 US on ebay.
512k chips are relatively uncommon and worth keeping and the 1mb ones have no gold but still fetch a commanding price.
Reply 8 of 20, by subhuman@xgtx
Quake 3
Reply 9 of 20, by Malik
Errmmm...perhaps dual boot with a Win98?
Reply 10 of 20, by swaaye
Quake 3 has experimental SMP support yup but it's of little benefit. It's also disabled by default. PPro isn't going to run Q3 well regardless ...
id didn't have useful SMP in an engine until Quake 4's upgraded idTech 4. I think it's most help for the consoles because of their weak CPUs. I didn't really see a benefit on my Athlon64 X2. There is also some kind of sync issue with it that causes occasional stutters.
Reply 12 of 20, by ratfink
With an SMP system you can do things like run two games at once smoothly. Of limited practical significance I guess unless you want to do a lot of alt-tabbing.
Also by running a game on a specific CPU (using 'set affinity' or whatever) could in theory speed it up a bit if background tasks run on the other CPU.
Reply 13 of 20, by JaNoZ
What ram is in there 512mb !!!! Edo 72p or 168p ?
I think a ppro is awesome there is not much improvement with 512k instead of 256k
Reply 14 of 20, by sliderider
Microsoft Flight Simulator X supports multiple processors, but doesn't do it very well from what I have heard.
Reply 15 of 20, by rgart
168 pin ram. The platform really interests me. Maybe linux or win98. Its such a loud system with all the fans going and the scsi. I would have to mod a case and replace the air flow system so it doesnt wake the neighbours 😀
Reply 16 of 20, by subhuman@xgtx
I has to be of partial help only because what SMP on quake 3 does is just allocating 1 cpu to the video part and the other to the sound core
Reply 17 of 20, by d1stortion
Even on games as late as HL2 SMP support was (still is?) considered broken so it is not surprising that the much earlier uses of it may be problematic.
Reply 18 of 20, by Logistics
Dedicated server for Doom/Heretic/Hexen/Duke3D/Warcraft2/C&C and the like, BBS server for running stuff like LORD and BRE.
Reply 19 of 20, by TS_486DX2-X1C
vetz wrote:
Doesn't Falcon 4.0 support dual CPU's?
Stunned speachless....not only flabbergasted that people still remember the dual Pentium Pro 200's, BUT Falcon 4.0 demanded I respond to this. First encountered Falcon 2 on a Compac 385-25. Became a squadron leader when F3 added the multi-element battlespace, with real Ops Orders in support of missions all within a full scale tactical level battlefield environment. That your successful ground attack on an enemy re-supply column that stopped a 155 battery from successful defence fire missions......or when your SEAD flight failed, and bomber flights were all taken out by enemy SAMs....allowing continued use of a re-supply FOB airfield. I was a squadron leader, and then an instructor pilot. I was Invited to join the beta team for Falcon 4.0 - and I kid you not, it took over 5 weeks to merely land the F16 correctly without breaking the gear, or destroying the afterburner ctrl cones cos my AOA was too steep.
It's been over 12 years since my last ultimate setup......projector on bedsheet, full thrustmaster HOTAS and adirondack for the perfect 60 degree posture with throttle & stick strapped to the arms.......
Sorry, I just rediscovered a longtime obsession - and off I went.
In short, the question of SMP is a difficult one. Like multi-threading - The OS kernel would need a complete re-build, as the app itself needs to refine the algorythm, for true parallel sequencing. This code has to be completely re-engineered from the ground up. I believe F 4.0 used the SMP to control all the individual elements, flown by avatar.
Anways....gonna shut up
Cheers for the trip down memory lane
TS
