dosbox runs too slow
First post, by daemon
Im using frebsd 5.1 i hit ctrl F12 to increase cpu cycle hmm games still run too slowly, im running doom1 i have a p4 2.66 mhz processor im guessing it should run fine..... im not really sure what to check i ahvent created a dosconf using the default. thnks
Reply 1 of 3, by eL_PuSHeR
You should try CTRL-F7 & CTRL-F8 to decrease/increase frameskipping respectively. Also, as some other forum members have suggested, you should try some port of Doom for your Operating System. There are lots of them and most work surprisingly well.
Reply 2 of 3, by icemann
Or download a doom source port which will work 100% fine on any source port like doomsday, legacy etc.
Two stones, two crosses, the rest is just icing. - 7th Guest
