First post, by bjt
Some games with Roland sound support suffer from buffer overflows with the Rev.0 MT-32. The symptoms are incorrect sound and the message "EXC. BUFFER OVERFLOW" on the MT-32's display.
SoftMPU 1.1 includes a feature that prevents these problems by adding small delays in MIDI transmission. Further info here: *START HERE* SoftMPU 1.91 - Software Intelligent MPU-401 Emulator
Reply 1 of 7, by Kahenraz
From what I understand, the MT-32's buffer overflow (too fast) is different from the digital overflow (16-bit data rolling over).
Can you confirm that this fix corrects only the buffer overflow, which can cause the unit to lock up, as opposed to the digital overflow which is what Sierra games used to make special sounds?
I'm not 100% certain that these two overflows are mutually exclusive.
Reply 3 of 7, by bjt
This feature of SoftMPU is sorely in need of testing so I'm glad you tried it. It does work with the one test-case I have (Populous).
I'll try to get hold of a copy of Gods and see what's going on.
Reply 5 of 7, by bjt
That depends whether you gave the port address of the MPU-401AT or the SB's MPU when starting SoftMPU.
Reply 6 of 7, by keropi
nope, gave it the roland mpu address.
I am almost 99% sure though that I also needed to enable the sb16 mpu in order to get softmpu going... When tested I gave it the sb's 220 port, sb's irq 5 and roland's 330 port
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 7 of 7, by bjt
Finally got round to testing this. SoftMPU 1.7, two configs:
- Yamaha YMF71x -> MT-32 Rev.0
- SB Pro 2 (SBMIDI) -> MT-32 Rev.0
On both configs I get the buffer overflow message when starting Gods. However with both the message goes away if I specify /DELAYSYSEX when loading SoftMPU. It seems like things are working as intended.
