dragonfly13 wrote:Since GM is using 128 instruments, are those instruments lined up in the first 128 spots on a first batch SC 55 just like on a GM only device with the whole extra GS stuff added in higher number "slots" that can only be accessed by games that were written for Sound Canvas/GS? I did a cross check with a SC 55 manual (no mention of GM anywhere in there but I can't tell for sure if it's a Rev. 0 manual or not) and the General Midi article on Wikipedia and the sounds seem to line up.
Yes. Just check out the neighboring thread for more details...
What I don't get is this whole variation stuff. Is GM also using variations or is it GS only?
Both variation tones and also extra drums are part of the GS spec. The SC-88 will use capital tones on all channels in GM mode but will still take all drums. This may and will differ for other synths.
I also thought about getting an extra unit (or two) for dedicated GM playback. For the first couple of years worth of DOS games after the SC55 release in 1991 I'm probably pretty well equipped with a first batch SC55. But later on the files got more and more complex and the polyphony is quite low on those early units. Also, from what I've heard early GM support seems to be almost always inferior to directly selecting Sound Canvas and sometimes even MT32.
You are set with the SC-55 for DOS games really. No need to worry about polyphony, generally game soundtracks weren't that complex. Most really just used a bunch of capital tones and no custom reverb/chorus values, not to speak of even more advanced features. 24-voice polyphony is enough for most games I believe.
What's your opinion on a Roland SC 88 Pro and maybe a Korg NS5R with an added XG compatible daughterboard for GM? This combination would cover a lot of the sounds that were en vogue back in the day. Or is a SC55 MK2 still preferable to a SC 88 Pro for GM?
Results will vary widely with those higher SCs. There are some DOS game SC-88ST Pro recordings on youtube which you can listen to. Some songs will sound great, some mediocre, some will sound broken. Don't forget that the SC-88/88Pro/8850 maps were not designed to be compatible with SC-55 material. For that there is a SC-55 map, but its accuracy will vary. On the SC-88 it's relatively good, as in you get all drums, strings, cheesy guitars etc back that are responsible for the characteristic SC-55 sound. I'd say it's about 80% accurate on this device, only considering the samples themselves. Models starting with the SC-55 MkII also have a better DAC. Chances are if you only care about DOS games the SC-55 may be enough for you.
