Serial Port
First post, by ik8ozv
Hi to the list,
Please apologise if already discussed.
I have tried to search but cannot find anything.
I have a terminal software wchich has to work with a serial terminal.
Please how to set the DosBox to comunicate?
Actually i am using an USB to Serial Converter.
How to set properly the CONF file?
I Have tried to put the line:
directserial realport:COM3
but when i run the program, the program seem to stuck.
I can read on the DosBox Status Window:
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file c:\Users\Enzo\AppData\Local\DOSBox\satsked.conf
MIDI:Opened device:win32
Serial3: Opening COM3
DOS keyboard layout loaded with main language code IT for layout it
Thanks.
Enzo
Reply 1 of 3, by Jorpho
Whyd did you put this in the PC forum and not the DOSBox forum?
That will probably not work. You should try using a computer with a real serial port first.
Reply 2 of 3, by ik8ozv
How to move it to the right section?
Unfortunatelyy PC does not has only 1 serial onboard
But it is broke.
How cam i do?
Thanks
Enzo
Reply 3 of 3, by Jorpho
Either get a new computer, or get a PCI card with a serial port, like http://accessories.us.dell.com/sna/productdet … 230881379347400 . (There are probably cheaper ones out there somewhere.)
There is still no guarantee that it will work, however. DOSBox is intended for games and not for serial terminals.
