First post, by Koenig
Probably the most beautiful thing I got for free.
This is a collection of Interplay games.
Here is a photo of it if any of you are familiar.
Re: Bought these games today
Courtesy of a user on this forum badmofo. (Thanks)
I'm trying to run the CD with the Multiple games on it (I WANT TO PLAY ULTIMA UNDERWORLD BADLY)
Here is my procedure (Win 7 32 bit runnind dosbox .74)
mount f f:/ -t cdrom
Mount c c:/
f:
dir
dossetup
I then chose wasteland out of the CD and it immediately said it was installed and to type in WL to play it but I checked the C drive and it was empty. I tried Ultima Underworld and it said it was installing for a while but then it wouldn't stop saying it was installing and I checked the C drive and no files were even put inside of it. The same thing happened with the Bards Tale as did with Ultima Underworld I.
I am wondering if there is another way I must do it or if the CD is damaged or compromised. Any guidance would be appreciated and I can apply more information below if requested (Take note I got Stonekeep to work under similiar procedure)
_______________________________________
I used a USB as a "Hard drive" to run Stonekeep by mounting it and installing stonekeep to it and for these games I am attempting to use my actuall C drive.
If you need my Email ask for it.
