First post, by waynrayn
Hi There:
I downloaded Dosbox Turbo into a tablet (Nexus 7, running Android 4.2.2). I then installed an old, small 16-bit DOS program that is not a game, but a GPS calculator. So the system requirements aren't very much.
To facilitate input, I also installed Hacker's Keyboard.
The DOS environment appeared to be fine. However, as I input the numbers I found that at one point, the program skips a line of input, and can't be backed up to that line. Obviously this causes problems with the calculation.
When I run the same program in the MS-DOS prompt of a laptop with Windows 7 or 8, the calculation is fine. The program does not skip a line.
I am unsure of whether the problem is the tablet keyboard or the Dosbox Turbo program.
I am wondering if someone can help with this. I can send an email with pictures showing the problem, or even the small program itself in a zip file. It's not very big.
Any help or suggestions would be appreciated.
Regards,
waynrayn
Reply 2 of 2, by waynrayn
Sorry, my mistake.
Thanx,
~W~
