First post, by Xenphor
So since Shadow Warrior is free on Steam I decided to set up my controls before playing but ran into a few problems.
I don't understand. You can map 4 axes in the game: x, y, rudder, and throttle but can only map 3 actions to those axes; they are: analog_strafe, analog_moving, and analog_turning. Now naturally I would assign strafing to the X axis and moving to the Y axis correct? Well apparently analog_moving is actually joystick looking up/down?? How does that make any sense?
So in order to play the game, I have to map two digital buttons to the y+/y- axis to simulate forward/backward movement and then use analog strafing for the X axis. Obviously this doesn't work out too well. However, the rudder and throttle work pretty well for turning and looking on the second analog stick.
Why would they not allow analog forward/backward movement but have side to side?
