First post, by emuola
I'm building my "dream dos-machine" (at least it would have been my dream machine back in the nineties) consisting of the following components:
-~486DX 100Mhz
-16 MB RAM
-plenty of hdd (depending on bios, possibly a flash module directly connected to ide)
-SB32 AWE (value/full)
-Roland MT-32 (preferably the CM-series/LAPC-I)
I want to use real hw (I already have all the other computers I used as a kid in working/maxed out condition), so don't tell me about Munt 😉
I've always wanted to experience the real MT-32 "heaven", because back in the day the module/card cost wayy to much. It seems the LAPC-I/CM-32L are pretty expensive and LAPC-I is very hard to find. So my questions are:
1. If I get the CM-32L external module I loose my gameport, right? (the SB32 sends midi to CM-32L via gameport?)
2. If I get the LAPC-I I don't loose my gameport, right?
3. If it proves to be impossible to get the LAPC-I, can I have another gameport in addition to the one the SB has to be able to use a joystick?
4. What would you use if you were in my shoes? LAPC-I or an external module (in addition to SB32 AWE)?
Thanks in advance 😀
Reply 1 of 7, by Mau1wurf1977
I believe that MIDI and joystick should work simultaneously. All you need is get a cable that has both MIDI and joystick ports. I have such a cable, it goes into the sound card and on the other hand has the MIDI connectors for the MIDI modules plus an extra 15pin plug for the joystick.
Regarding internal vs. external, I always recommend going with external modules as they are more flexible, can be used with many machines, DOSBox, ScummVM and don't need a -5V PSU.
My YouTube channel
Reply 3 of 7, by emuola
Thanks for the info 😀 It seems that the external module(s) also are very hard to find nowadays 🙁 Only a couple of CM-32P (worthless without CM-32L?) listed in Ebay. Any hints on how to get one? 😁
@keropi, just saw your post when pressing "submit" 😀
Reply 4 of 7, by keropi
yep, P is pretty much worthless, you are better off with a midi daughterboard than a P module IMHO
about getting one... ebay watching, place a wanted ad in forums... vintage computer forums and quest studios are good places IMHO for such an ad
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 5 of 7, by emuola
Thanksagain keropi 😀 I posted an "ad" in vintage computer forums. Unfortunately quest studios had their forums disabled.
