First post, by rgart
Here's a Forex Motherboard.
Unfortunately I cant find a photo of it with cache installed and I cant recall which way the cache went before I removed it.
Is there an easy way to tell?
Should I just follow the alignment of the other chips?
=My Cyrix 5x86 systems : 120MHz vs 133MHz=. =My 486DX2-66MHz=
Reply 1 of 4, by 5u3
The sockets have a little notch at one side (in your pictures they're on the upper side). The cache chips have a little indentation in the plastic that looks like a semicircle. Align the chips so that the indentation matches up with the notch in the socket.
Reply 3 of 4, by rgart
Theres no voltage Jumper on this board and absolutely nothing in the manual in regards to voltage.
The old 486 boards were 5volt standard?
How about a 486 DX 33 CPU? 5 volt?
Im searching now for some reading material but does anyone know?
Reply 4 of 4, by 5u3
Yes, 486DX/33 is 5V. 486s requiring 3V usually have the voltage printed onto the top.
