First post, by elektroschock
elektroschock
Offline
I would like to change the text of the dosbox menu frame. My idea is to use dosbox as a compatibility layer with an old dos application of mine preinstalled. Do I have to hack manually in the dosbox sources or is there an option to change the window title? I think in order to avoid the shell it is enough to start the app via autoexec and enter "exit" to the autoexec.bat.
