First post, by tincup
I seem to remember there was a pincer-like tool for cleanly removing motherboard cache modules, but I can't seem to track anything down yet. Anyone know if/where these can be sourced. My set of 486 modules are getting a bit banged up at this point just gently prying them out of the socket...
Reply 1 of 9, by 133MHz
What you're after is called DIP extractor tool and can be sourced from any decent electronics stores.
http://133FSB.wordpress.com
Reply 2 of 9, by Hatta
But good luck finding a decent electronics store! 🤣
Reply 3 of 9, by tincup
I'm on it!
Reply 4 of 9, by BigBodZod
I remember these for the DIP socketed chips, I have one stored someplace I bet, also had one for PLCC type sockets too.
No matter where you go, there you are...
Reply 5 of 9, by rgart
http://www.ebay.com.au/itm/PLCC-IC-Chip-Extra … =item3371c079b9
That, a small flat head screw driver and some gentle hands will do the job.
=My Cyrix 5x86 systems : 120MHz vs 133MHz=. =My 486DX2-66MHz=
Reply 6 of 9, by tincup
That's what I've been trying to do so far. But it's tight for space in there and difficult to gain side leverage. A tool that worked from above would be nice. I see a few on ebay but will check the stores here first...
Reply 7 of 9, by rgart
Pull the motherboard out of the case.
I had a similar problem with the cache on one motherboard. They were so tightly packed I couldnt use the tool. Had to use a flat head screw driver ever so gently.
Reply 8 of 9, by Stojke
Cheapest way - Flat screwdriver and gentle movement. First practice a bit you will develop your own technique of extracting it with out damage.
Best way is to get hard plastic clippers, those wont damage the ceramic casing.
Reply 9 of 9, by tincup
Haha - practice... I'm doing pretty good and will consider this set of chips "trainers" if it ends up badly [they were cheap]... Hopefully all the fussing will be moot with the arrival of a replacement TAG chip - seems my basic problem has been a TAG of the wrong mhz...
