First post, by chinny22
- l33t++
I've got a question about Fixed disk CF cards if anyone can help
After my games HDD in the 486 died awhile back I thought I would give CF cards a try. I went and got my self a fancy Sandisk Extreme 60MB/s like below as they were on special.
After messing around for a day I have learnt much but sadly don't think I can use this card for this setup.
Trying to set this up on my Dos 6.22 486, BIOS detects the correct size but using the updated Win98 fdisk I cant create logical drives over a couple hundred MB where my 10GB HDD would partition fine (Taking in account the 8GB limit)
I tried to partition it with gparted and can make the logical drives fine and show correctly in WinXP but Dos can only see the primary partition. Fdisk can see the extended but no logical drives.
I'm pretty sure this is because it is still not in fixed disk mode but using ATCFWCHG.com just gives errors.
I've also found out that the speed depends on the mode so may well drop when used in an old PC.
So my question is what 8GB CF cards do support fixed disk and are there any that are faster then others?
As for the above card, as long as its a single partition I'm pretty sure it will work, (will try tomorrow) Once I get my 2nd 486 from my parents I'll run dos 7.1 and use it on that but with 6.22 I'm stuck with Fat16 2GB partitions
