First post, by Pingaloka
- Member
HI guys, trying to tweak my 233MMX to get as slow as possible without comprimising speed.
The Motherboard:
SOYO, SY-5EAS5
Supports MMX, goes up to 200-233. 512kb cache and PS2 mouse port.
- Set to 66mhz 3.5x = 233MMX
- 32Mb Ram FPM
- S3 Trio64v+ 4mb
- SB16 2230 + NEX XR385 + MT-32 Roland (old)
At 233mmx without L1 and L2 Cache I got a result of 13.67 in Speedsys...the equivalent of a slow 486 I would say....
Would it be possible to slow down even further this machine? The problem with MMX is that they are not very good for slow down purposes due to their CPU onboard cache as we already know...so the slowest setup to try to achieve bigger slowdown would be 50mhz x 2.0 which gives us a Pentium 100MMX. I'm using a 233MMX so the 1.5x jumper setting works as a 3.5x, the slowest I can go therefore is 2.0x...what a pitty.
Ok, so what I wanted is to have a 233MMX one minute and a 100MMX the next one without to much of hustle. Why? because the 100MMX setup without L1 and L2 cache gives us a 9.17 score in Speedsys which is more or less like a 386/40mhz
(An AT BOX is needed because of the turbo button)
I got the turbo button cable and cut it. Splited the cable in two with the help of this little black plastic thingy which I don't know the name of.
AS you can see, the turbo cable goes into the the black plastic thingy and on the other side I joined 2 jumper cables in total. The original turbo one and a new one:
I plugged one cable where the multiplier jumpers are (in multiplier 2.0x) and the other cable in the
50mhz jumper position, where the frecuencies are at.
So know, I just need to press the turbo button to go from a 386/40Mhz, 9.17 score in Speedsys up to a Pentium 233MMX with a 176.70 score in speedsys. Pretty handy right? 😎
I wanted to share this because it is quite easy to do, and it makes as closer to the all-in-one-impossible Dos Machine.
I know, I know....Amd K6-2's are better for these purposes!
Here some pictures:
(Speedsys shows setup of 66Mhz 1.5x but it is actually set at 50Mhz 2.0x on motherboard...weird...)
