ctl alt del causes hang
First post, by badmojo
I'm putting together a 486 using an Aopen (Acer) brand VLB motherboard:
http://stason.org/TULARC/pc/motherboards/A/AC … ml#.UgggEdIwf3t
It's working OK, but doing a soft restart using ctl alt del causes the system to hang instead of reboot. If for example I'm at the DOS prompt (clean install of DOS 6.22) and I hit ctl alt del it'll just sit there, prompt still visible but no longer accepting input from the keyboard.
Has anyone seen this before? This board has that stupid graphical interface bios so there aren't many options to fiddle with.
Reply 1 of 6, by Malik
Ermmm..have you tried waiting for 5 or 10 seconds?
Reply 2 of 6, by leileilol
Does it on my M919 if I have the memory timings set too tight.
long live PCem
Debian's fucked
Reply 3 of 6, by NJRoadfan
Is EMM386 installed? If so, does the machine reboot as it should when in real mode? It can do weird things like that. You can also try EMM386's "alt boot" switch to get around the problem.
[ALTBOOT]
Specifies that EMM386 use an alternate handler to restart your computer
when you press CTRL+ALT+DEL. Use this switch only if your computer stops
responding or exhibits other unusual behavior when EMM386 is loaded and
Reply 4 of 6, by badmojo
Thanks for the suggestions but no, waiting doesn't help and the EMM386 tip was a good one but didn't make a difference either. I've noticed also that memmaker can't reboot the machine, and now that I think about it neither the DOS installer nor the creative software installer rebooted the machine when they should have either. They just sat there.
I'll look at the memory settings in the bios, but currently it's set to auto config that stuff, so the timings shouldn't be too tight.
Very annoying, I'm building this thing to sell and although it seems to work fine, I don't think I can bring myself to sell it to someone if this doesn't work. Bloody quirky 486s.
Reply 5 of 6, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
If the keyboard controller can be replaced it's one option to check out.
1+1=10
Reply 6 of 6, by badmojo
It's soldered on! And I noticed that the turbo LED header doesn't work on this board either - the switch does, but the LED is always on.
That's it, I'm going to hand it on my wall of dead hardware.
Thanks for the replies.
