First post, by Darkfalz
Darkfalz
Offline
Okay, two quick things. It's possible one or both of these are addressed in the CVS, so if that's so, ignore it.
Firstly, XCOPY emulation would be a good idea. Not only because I'd like to use it from within DOSBox, but many cheapo installation programs (ie batch file) use it to install games.
Secondly, whenever you copy files inside DOSBox using normal DOS copy routine (either command prompt or inside a program) then the files generated are stamped with the current time, rather than the time of the original files. A nit picky thing, but would really be better if it was fixed.
Thanks! 😀
