First post, by Yasashii
I have a CMI8738 currently plugged into my windows 98 machine but I also have an ESS Solo-1. The question is, is it better than the CMI-based card or not?
Will it work with DOS games on win98? Does it have OPL3 and all the stuff you'd need to play DOS games properly?
Reply 1 of 3, by bjt
Don't think any ESS has a real OPL. I hear ESSFM isn't too bad though. What about a PCI Yamaha card?
Reply 2 of 3, by swaaye
ESFM is pretty good and often extremely similar to OPL3. I'd just try it and see if you like it. Solo 1 had a lot of focus on DOS legacy support and that's why it has FM hardware.
I have some OPL3 (SBPro2) and ESFM (ES1869) recordings.
http://www.mediafire.com/folder/uc37ntgrkgxhr … Card_Recordings
Reply 3 of 3, by Yasashii
It should be good enough, then. Thanks.
