First post, by CU_AMiGA
Hi Guys
Just ran into a problem here installing the Windows 3.1 drivers for my Diamond Stealth 64 PCI card. The installation itself seems fine and when the machine boots into Win 3.1 for the screen mode configuration it seem OK with that too. The problem occurs after I saved the settings and the machine requires a restart. Basically after Win 3.1 has restarted I'm just presented with a blank screen (still a VGA signal) and Win 3.1 won't start up - thus requiring a reset.
Its probably worth mentioning that I am doing a dual boot with Win 98se, but I had no problems like this before I installed these drivers, nor with my old ATI Mach64 with their drivers installed. Can anyone shed any light on this issue?
Kind Regards
Reply 1 of 1, by Anonymous Coward
Stealth64 encompasses dozens of different cards using various chipsets. Which model do you specifically have?
