First post, by blackmountain1983
I have the CD Rom Game: TIME COMMANDO made by Activision for Windows 95 and DOS. It is too old school to run on my computer normally. I was able to get it to work using DOSBOX, but only once.
Apparently, Time Commando was only temporarily installed using the DosBox Emulator, so once DosBox Closed, I had to reinstall it, but when I tried to install it a second time, I got this error message:
Error Code 9005
The installer was unable to find a suitable temporary directory.
You may specify one on the command line by invoking:
D:\DOS\INSTALL.EXE SwapDir=d:\path
If your computer is part of a network, please ensure that you have adequate rights to create a subdirectory and a file on the path you specify.
My computer is not part of a network. So I tried:
D:\DOS>INSTALL.EXE SwapDir=d:\path
and got the same error message. Then I figured that perhaps "path" meant that's where I should type where I want the temporary directory to be, to I tried replacing "path" with C: and I got the same message. Then I created a new folder within C: called "timecommando" and then tried replacing "path" with C:\timecommando and I got the same error message. Then I tried replacing "d:\path" with C:\timecommando and still got the same error message.
Anyone have any idea how I can get this game to work again?
Reply 1 of 6, by Jorpho
I'm not sure what you did, but considering DOSBox cannot recognize filenames with more than eight characters, there is no way a folder named "timecommando" is going to get you anywhere.
Did you follow the 60 Seconds Guide ?
Reply 2 of 6, by blackmountain1983
Ok so I shortened the folder name to "timeco" and it still did not work.
as for what I did, I started by typing
MOUNT D D:\ -t cdrom
then once on D: I typed
CD\DOS
and then once at D:\DOS> I typed
INSTALL
as per the Time Commando Instructions
Reply 4 of 6, by eL_PuSHeR
[Thread moved to DOSBox Games/Apps. Section]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 6, by blackmountain1983
Dominus wrote:
Follow the 60 seconds guide. You need to mount something for c, too
Perfect, it worked great! Thank you!
