First post, by abayko
I am currently trying to find a way to get this software running properly in DosBox. The problem I am encountering is that when the program switches from the main editor to the library manager, DosBox closes and the error "unhandled dos 21 call 53" appears in the status window. Aside from that, the software appears to be operating normally. The library manager can be invoked separately without any issue.
DosBox version 0.74
Draftsman ee version 4.17
Windows 7 running on a dual core 2.4 GHz system with 4GB ram. 32 bit version of windows.
Toshiba laptop Sattelite A210 with standard video and audio.
Problem occurs always and results in dosbox shut down
Problem seems to be in the main editor. I can rename the library manager (so the editor cannot find it) and the same error occurs. Looking through the DOS int 21h calls 53h seems to be a disk access of some sort. The program is only having trouble when the library manager is being used. The editor can load up the files if it is given a specific file name as opposed to browsing the libraries.
This program is used for printed circuit board design so it is similar to autocad in it's use.
