First post, by Robin4
- l33t
Does some ones knows about the factory 5v hardwired on the socket 3 chaintech 4sld motherboard??
Is seems that this board could support 3 and 4 volts processors.. But mine doesnt havent the voltage regulator installed..
and a section that needed a jumper block, only have a soldered wire in it..
Its just the same board:
