First post, by squareguy
- Oldbie
Part 1.
Well I am fed up with today's games and really want to relive the glory of old. Great games with inferior graphics maybe but really great game play. I guess that's why we are all here.
This is an attempt to document my retro build. I do not expect to tell you anything you don't already know and I am not trying to act like a know it all. Just expressing my thoughts out loud and if I post incorrect information just say so that I may correct it. This is my opinion on how a machine should to be built to play the games I love, nothing more. I will try to not be long-winded or go into overly technical mumbo jumbo speak.
Stability and compatibility are key to me. Stability above all. That does not mean it will be compatible from your viewpoint, with your games. I will try to explain my choices as I go.
This project will take some time to complete so do not expect it to be finished overnight. I will be using NOS (new old stock) parts wherever possible and original pressed software CD's. I will discuss software and drivers once machine is up and running.
Remember... beige is beautiful.
Parts needed, in no particular order. I do not intend to install a modem or network card.
1. Operating System
2. Motherboard
3. CPU
4. RAM
5. Video Card(s)
6. Sound Card(s)
7. Hard Drive
8. Floppy Drive
9. Optical Drive
10. Case
11. Power Supply
12. Keyboard
13. Mouse
14. Mouse Pad
15. Speakers
16. Monitor
17. UPS, to protect mostly against brownouts.
1. Operating system: Windows 98 SE (Second Edition).
Why? Because it is basically a better version of Windows 95, doesn't suck like Windows ME, DOS compatible, supports 16-bit code (Both DOS and Windows), supports old versions of DirectX, very configurable, vast amounts of hardware and software support from that era. Lots of great games were written for this OS.
Status: Brand new Windows 98 SE CD, COA and floppy on hand.
2. Motherboard: Intel SE440BX-2
Why? Because Intel did things right. The BX chipset was stable, fast, compatible, stable and stable. The SE440BX-2 motherboard was a very stable and well designed motherboard. It wasn't all that popular back then with enthusiasts due to one simple reason, overclocking. Overclocking a retro machine is completely unneeded for me and goes against the principles of stability and longevity of the system. Sigh, I still miss my Celeron 300A and Abit BH6 though. Choosing the correct revision allows me to use any Pentium II or any Pentium III (100-MHz Bus only, not the 133-MHz Bus EB series) Slot-1 CPU available so no overclocking will be needed for my gaming needs. It has 4 PCI slots, 2 ISA slots and an AGP 1.0 slot. It fits my needs perfectly.
Status: Brand new SE440BX-2 motherboard on hand (The revision I have handles the P3's with 256kB on-die L2 Cache), flashed to latest P17 BIOS and awaiting installation of a new CR2032 battery.
More to follow...
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
