First post, by catchaserguns
- Member
I'd just got this Dell computer and I tried to uninstall xp. Now I'm in some sort of loop in which i cant uninstall and the uninstall process keeps on repeating itself. At the end of the install it says setup cannot create the folder \America Online 6.0\download\FlyerForMarch2. Setup cannot continue until this folder is created. I press enter and nothing happens. When I press F3 to exit setup it restarts the computer and the uninstall process starts all over again. I can't even install another OS because its stuck in that loop. I even put in the xp install disc and it continues in the loop so I can' t delete the partition. Any help will do. Thanks
