Disk swap support?
First post, by Darkfalz
Correct me if I'm wrong about this, but it seems DOSBox doesn't recognise changing floppies/CD-ROM once it has started. It still thinks whatever you had inserted at the time is the current disk, no matter how many times you've changed it.
Now I am loading these properly as floppy/cdrom using this:
MOUNT A A:\ -t floppy
MOUNT D E:\ -t cdrom
Obviously, this rules out playing multiple CD games, and even rules out installing games from original floppies.
Is this fixed yet in the current CVS?
Reply 1 of 4, by eL_PuSHeR
Assigning a hotkey to RESCAN command would be good.
Reply 2 of 4, by Darkfalz
How are you going to issue a RESCAN command inside a program which is asking you for the next disk/CD?
Reply 3 of 4, by robertmo
with a hotkey, right not it is not possbile 😉
Reply 4 of 4, by Darkfalz
A hotkey would be a good idea, a better one would be for DOSBox to actually recognise disk changes externally (and thus internally).
