First post, by pauldow
Hello,
I'm trying to get an old DOS based database application running on a 64 bit Windows Server 2008 R2 system.
I've installed DOSBox, but I have a bit of a problem. The application is 'menu.exe', and it seems to have links to that name within other .exe and .bat files within the directory that get called.
When I enter the command 'menu' or 'menu.exe' it just brings up the 'Welcome to DOSBox v0.74' message box. I tried copying menu.exe to menu2.exe, so it wouldn't use the internal function, but I get the same result.
Is there a way to get this to run?
is there a way to disable the internal DOSBox 'menu' command?
Thanks
