Hippo 12 VIP MOBO
First post, by Pingaloka
Hi guys, just got this motherboard. There was a little bit of corrosion but got rid of it with some alcohol.
I'm trying to find a manual for it but no luck whatsoever.
Any help is appreciated. BTW a question for the experts. Is this a good motherboard?
Reply 1 of 2, by Tiremaster400
http://stason.org/TULARC/pc/motherboards/O/OC … ml#.UlK7mdK-qfY
closest I could find, I have two Hippo 15 motherboards and the manual does not match precisely.
It appears to support any 486 ever made and has multiple voltages and fsb speeds. I'm going to be using mine for overclocking projects, mine were OEM Gateway 2000 motherboards.
It also supports write back cache!!
Reply 2 of 2, by Pingaloka
Thanx Tiremaster400, it does look like a good MOBO!
