First post, by bozman
I have a couple of exe's that do not seam to run correctly within the Dosbox environment and I was hoping that someone might be able to give me some advise.
The exe's in question are LEXGTI.EXE and TAG2GTI.EXE , basically these two 16 bit programs are used to look inside a file for certian strings of data (more specifically incorrect data strings).
At the end of the process I should be left with 4 files ( this works from the command prompt in XP ) but in Dosbox I only get 2 files returned.
Are there any tricks to getting some applications to run ?
