DOSBOX and machine name
First post, by Wombat
Is there a way I can get DOSBox to retrieve or set via the conf file the Machine Name?
I'm trying to run a FoxPro for DOS application under 64 bit Windows 8 and the FoxPro code retrieves the machine name and sets some special variables based on the name returned.
Reply 2 of 3, by Wombat
Argh. Okay thank you for the response.
There are a lot of posts over at Microsoft's FoxPro forums suggesting DOSBox as a solution. It works except for a few low level builtin functions.
I'll find another solution. 😎
Reply 3 of 3, by leileilol
Unfortunately those are misleading posts as DOSBox is not suitable for data-entry and non-gaming purposes. A real virtual machine software (such as Microsoft's own Virtual PC, go figure) would do better for FoxPro.
long live PCem
