First post, by Aldeb
Hey. I'm installing Win98 on an old machine I got and I need some general tips and advice (I've never done this before). The computer was made 1999. Planning to use it for old gaming.
Specs: Intel Celeron 400 Mhz Processor
192 MB RAM
SiS 4MB Video Card (wiill to upgrade to an AGP Ati Rage 32 MB card)
4GB HDD (must upgrade to 20 GB)
Yamaha DS1X Native audio
Standard floppy drive
DVD-Rom
USB Mouse and Keyboard
Right now it's running WinXP (very, very poorly). My number one concern are drivers. If I reinstall, will win98 ask for drivers or will it install generic video card and audio drivers (as it usually does with Windows XP)?
And if not, where should I look for drivers?
Is there anything I should salvage from the current installation (driver names, maybe some files) that would help me out with Win98?
Anything else I should consider before reinstalling?
Reply 2 of 10, by Aldeb
Checking. It needs 5 minutes just to power up. Everything on the motherboard is on AGP or PCI respectively (video, sound and network). Nothing onboard. will I need to manually install drivers for these cards or can Win98 handle some of them by default?
Reply 3 of 10, by d1stortion
Every Windows version since at least 95 has built-in drivers for some hardware, but the question is whether you want that convenience or if you wouldn't mind looking for newer versions online (which is not always the best thing to do, especially with old video cards, though).
Reply 4 of 10, by Aldeb
Ha nice. Wmic says the motherboard is a Biostar M6TBA - http://www.motherboard.cz/mb/biostar/m6tba.htm
I've never heard of biostar up until now. guess i'll write down the model names and look for the drivers online.
Reply 5 of 10, by Mau1wurf1977
ftp://ftp.biostar-usa.com/drivers/
ftp://ftp.biostar-usa.com/manuals/M6TBA/M6TBAmanual.pdf
The chipset is quite important. You need them, then also the drivers for the sound card, network card and graphics card.
It's not that many drivers to be honest 😀
PS: Chipset is Intel so this should be very easy...
My YouTube channel
Reply 6 of 10, by Aldeb
Thanks for the link!
Reply 7 of 10, by Aldeb
Several months later and I got my Win98 gaming computer working. It was a rough ride.
I had to change the sound card and the video card. Finding proper drivers was a nightmare (made more so by the fact that I couldn't get the USB interface to work, making data transfer much harder). But I finally got a TNT M64 and a pci sound card to work
My current issue now are with audio CDs. Win98SE won't play them. The volume is enabled and set on high, the CD-Rom works and does its thing while CD Player (win98's default audio cd program) will detect and play the tracks but nothing is heard. dxdiag and Device Manager all look ok
This issue is bothersome when I try to play games. I get the issue on both Windows and dos based games. Any suggestions?
Reply 9 of 10, by Mau1wurf1977
Yes that's likely the issue 😀
Get that audio cable that goes from the back of the CD drive to the Sound Card. Also set the Audio mixer so that Audio CD is mixed through.
My YouTube channel
Reply 10 of 10, by Aldeb
Lol yeah it was missing an audio cable. I had no idea it needed those. I found a replacement one and it works perfectly now.
thank you!
