First post, by insectoid
- Newbie
I've been trying to get D/Generation to work in full color in DOSBox 0.74. I've tried it in real-mode DOS on a Win98 machine, and it comes out looking like this screenshot from Screen Thief:
However, I've tried it in DOSBox on my Win7 machine, both 0.74 and the latest SVN build, in multiple video modes (S3, ET4000, nolfb, down to vgaonly) and it always comes out in mostly-grey, like this screenshot:
My dosbox.conf file is attached, though I have tried running with the defaults (no conf) with the same results. I've also tried varying the cycles (3000 instead of 10000, for example). The sound and the game itself work great.
My machine: Core i5-2400 3.1GHz, 8GB RAM, EVGA nVIDIA GeForce GTX 550 Ti 1GB, Windows 7 Home Premium 64-bit. DOSBox versions: 0.74, SVN r3838. I haven't tried any older versions because having multiple .confs for certain environments is already tedious. 😉
Thanks!
P.S. Off-topic, but related to the SVN build: I noticed that the %CONFIG% environment variable is not being used by the CONFIG command in the SVN build. Is this a permanent change? I find it useful for batch files (testing for settings with 'CONFIG -get')
Bzzz.
