First post, by Space Cowboy
New questions at 3rd page 😀 😀
Hi people, I spent some time at this forum and I think I got the disease 😀
I'm about to revive my old 486 PC. Definitely. And I need some advice. I've used it once upon a time with Windows 95, and I don't remember having any problems with it.
It's an old Unisys low profile box. Horizontal, and very low profile. I can't find the corresponding image in google, so picture will be attached later, but specifics are as follow.
- Sis 85c471
- Integrated Video Cirus Logic cl-gd5428080qc-a with 3 memory expansion slots (total of 2 MB I suppose)
- 3 ISA slots on a riser card in configuration 2-1 (1 on the one side, two on the other)
- Like ... ten empty cache memory slots
- CPU - unfortunately, the original DX2 (as I remember) is nowhere to be found. I have a DX4-120 with one of those clip-on 40mm coolers for it, but never tested if it works. (I need to arrange jumpers first)
The good:
- the box has all the jumper settings stuck on a piece of paper inside
- the integrated video was OK back then (and I can get more memory for it)
- PS2 keyboard and mouse on the back
- onboard cache is missing, but I think I found some chips from a dead Sis 85c497 board (could give them a try)
The bad:
- only 2 available ISA slots - so the question is - can I put a riser card with PCI slots? Anyway, I have the video onboard, and the soundcard will be ISA, so I can live with it.
- low profile box just don't have the feel of a full size box. Plus - if the PSU dies, I don't think I'll find a replacement - if it's only capacitors, I can fix it, but nothing else is in my competence. On the other hand - it won't take that many space.
- chipset is somewhat old.
So ... should I even try to revive this MB, or better look for another if I'm about to run a 486?
