First post, by bristlehog
- Oldbie
I have installed the card into a new system (Socket 7 P233 MMX) and it seems there are some driver problems. I'm unable to run Terratec Win98 software, it all says that there are no drivers. There's no 'Terratec EWS64 Synthesizer' in Multimedia section, only FM and MIDI-2 (which seems to be a daughterboard header).
There is PCM sound present though and if I run DOS games in a DOS window, there is also only PCM sound but no GM music heard. If I reboot to DOS mode, there is both PCM sound and GM music.
What kind of evil magic is this?
Here you can get fantastic wallpapers created by a friend of mine: patreon.com/Unpocodrillo
