First post, by Agent of the BSoD
- Member
Hi. So I have this odd issue with TR1 and the audio pack where the background songs play where they shouldn't. One instance is where the ambiance songs continue playing when the level completion screen appears, and at that point the song should have stopped playing. (same thing happens for cutscenes like the one at the end of level 4) Another instance of it happening is when I quit the game. The menu music starts playing from the beginning once the game window has closed and will continue to play until I close GliDOS completely. (it doesn't loop, just plays the entire song from beginning to end once) I've noted this issue in previous versions but it still happens even with the latest 1.53b version.
Some specs: (taken from Speccy)
Operating System: Windows 7 Home Premium 32-bit SP1
CPU: Intel Pentium D 840 @ 3.20 GHz
RAM: 2.00GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
Motherboard: Dell Inc. 0YC523 (Microprocessor)
Graphics: 128MB ATI Radeon X300/X550/X1050 Series (it's really an x600, the drivers make the name funny)
Audio: SigmaTel High Definition Audio CODEC
I'm using the CD-ROM version of the game. I've tested a few things with this and it appears to happen regardless of the settings I pick, like using VDos32 vs DOSBox, psVoodoo vs OpenGlide, fullscreen vs windowed; always seems to happen. It doesn't happen if I don't use the audio pack, though oddly I don't hear any music when I don't use the audio pack. (sound effects still play)
I could try a recording of this if it would be of any help.
Pentium MMX 233 | 64MB SDRAM | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 98SE
MT-32 (old) | SC-8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro Turbo
