First post, by nadnadnad
I'm sorry if this is something stupid, but I've ventured throughout the whole forum, but I couldn't find a solution to this problem. Bear with me.
Using DOSBOX Daum build with HAL's NE2000, virtual printer, and so on...
Problem: Everything works 'cept for the NE2000, which I want soooo badly. 😢
What works so far: DOSBOX detects my Wi-Fi adapter, and the packet driver loads at 0x60.
What doesn't work: Arachne, Lynx, ping, dhcp, and so on... in other words, no internet (no IP)
Debug window info:
DOSBox version SVN-Daum
Copyright 2002-2013 DOSBox Team, published under GNU GPL.
GUI: Press Ctrl-F10 to capture/release mouse, Alt-F10 for configuration.
CONFIG:Loading primary settings from config file dosbox.conf
"vga" is not a valid value for variable: machine.
It might now be reset to the default value: svga_s3
Memory sizes above 31 MB are NOT recommended.
Stick with the default values unless you are absolutely certain.
forcerate I got ''
MIXER:Got different values from SDL: freq 16000, blocksize 512
SDLNet_TCP_Open: Couldn't connect to remote host
TiMidity: can't open control connection (host=127.0.0.1, port=7777)
SYNTH: Specify .SF2 sound font file with config=
MT32: Control ROM file not found
MIDI:Opened device:none
ISA Plug & Play BIOS enabled
Parallel1: BASE 378h
Glide:LFB access: read-write
Glide:Unable to load glide2x library, glide emulation disabled
Using Network interface:
wlp3s0
(no description)
Output does not support hardware scaling, switching to normal scalers
[END OF DEBUG]
Some images:
In the attachments.
