First post, by Skyscraper
This thread is about my Asus P4PE motherboard and P4 3066 CPU and how they scale with diffrent DX9 video cards.
I thought it would be intresting to see what the optimal video card would be for a P4 system from year 2002.
It is unnecessary to go for a powerful and expensive AGP card if the CPU bottlenecks it to such a degree that it dosnt give any extra performance.
First the system spec.
CPU: P4 3.06 (HT on)
Motherboard: Asus P4PE
Memory: 2x512 mb DDR
HDD: Samsung 120gb 5400 rpm
PSU: Chieftec 400w
Operating system: Windows XP SP3 fully updated and bloated, not optimized.
Everything exept the video cards and the HDD could have been bought late 2002.
I will run all benchmarks both at default speed and slightly overclocked.
The default speed will be 3100 mhz and not 3066 mhz since this is the default speed* on the Asus P4PE board.
The overclocked setting will be 23*150 = 3450 mhz.
Both settings use default voltage but the P4PE overvolts some at idle and has a impressive 0.1v vdrop when the system is loaded.
*131, 132, 133=135, 134=135, 135, 136, 137...
Here is the system on my test bench for easy access.
I will start of with some general benchmarks.
I use old benchmarks that also will run under windows 98 so I can compare against my old boxes.
Seeing how much performance improved from 1998 to 2002 is breathtaking.
Superpi 1M
PCmark 2002
Sisoft Sandra 99
Reply 1 of 25, by [GPUT]Carsten
Your question as to what would be a fitting DX9 video card entirely depends. If you like to enable very high resolutions (Full-HD or even more) and antialiasing/anisotropic filtering levels, then you will be able to max out almost any DX9 card with only a single GPU like the X1950 XTX which has an AGP version from Gecube. This card is in most cases (i.e. games) a much better choice over the Geforce 7800 GS - except for some canned benchmarks probably.
If you, otoh, run SuperPi and Sandra like in your benchmarks to show the CPU-speed, then you will naturally not benefit at all from a fast video card.
Reply 2 of 25, by Skyscraper
The benchmarks with the diffrent DX9 cards are coming 😁 This was just a presentation of the system.
And no, I will not use SuperPi or Sandra as a graphics benchmark...
When it comes to resolution I will not use higher resolution than 1024*768 as I have a HUGE 34" CRT monitor that will not go higher. This monitor will in time be used with all my retro boxes.
I will use 3dmark2000, 3dmark2001 and 3dmark2003 as benchmarks since it is games from this time period (2001-2004) the system is built for.
Reply 3 of 25, by Skyscraper
The first batch of cards.
All ATI cards will use Catalyst 9.3 since I am lazy and it works with all cards.
From left to right.
Radeon 9550 256mb, Radeon 9600 pro 256mb and Radeon 9600 XT 256mb.
ATI Radeon 9550 256 mb 3dmark 2000
ATI Radeon 9550 256 mb 3dmark 2001
ATI Radeon 9550 256 mb 3dmark 2003
ATI Radeon 9600 pro 256 mb 3dmark 2000
ATI Radeon 9600 pro 256 mb 3dmark 2001
ATI Radeon 9600 pro 256 mb 3dmark 2003
ATI Radeon 9600 XT 256 mb 3dmark 2000
ATI Radeon 9600 XT 256 mb 3dmark 2001
ATI Radeon 9600 XT 256 mb 3dmark 2003
The 9600 pro and the 9600 XT bench simular but the 9550 is notably slower
A slight overclock can bring the performance of the 9550 more in line with the other two cards.
Conclusion so far.
These cards are too slow* and I dont have a working 9700 pro or 9800 pro so its time to move on to some newer ATI cards.
*overclocking the CPU gives no benefit in 3dmark 2003 so the GPU is the bottleneck.
Reply 5 of 25, by GeorgeMan
Perhaps OP needs something about ~9000-10000 marks on the 3dmark03, which measures almost directly the VGA and the CPU does not affect so much the score.
As far as I remember, my X1800XT (early pci-e) was ~17000 marks, so maybe a Geforce 6600GT AGP (late 2004) would be the the best choice? 😀
Acer Helios Neo 16 | i7-13700HX | 64G DDR5 | RTX 4070M | 32" AOC 75Hz 2K IPS + 17" DEC CRT 1024x768 @ 85Hz
Win11 + Virtualization => Emudeck @consoles | pcem @DOS~Win95 | Virtualbox @Win98SE & softGPU | VMware @2K&XP | ΕΧΟDΟS
Reply 6 of 25, by Skyscraper
Only one card this time since it is hard to get a good overview of a wall of pictures like in my last post.
The Radeon X800PRO
Radeon X800PRO 3dmark 2000
Radeon X800PRO 3dmark 2001
Radeon X800PRO 3dmark 2003
The Radeon X800PRO is proably fast enough for the games I want to play, at least @ 1024*768 but I will try a faster card to see if things improve further.
And lets not forget the Nvidia cards.
Mau1wurf1977 wrote:
I had a 2.6 GHz northwood and a Radeon 9800. It was a pretty well balanced system as far as I remember 😀
Until Farcry and Doom 3 that is 😁
Yea for a 2.6 ghz northwood the 9800pro must have been a great card!
The only 6600gt I have is a PCI-E card but I have a 7600 GS or GT AGP, I will try that card later.
Reply 7 of 25, by GeorgeMan
It really doesn't matter as the X800 Pro sits just perfect. 😁
Reply 8 of 25, by Skyscraper
This card is probably a bit overkill 😁
The X1950PRO
I forgot to reconnect the fan when I put the cooler back on the card... It seems it dosnt need a fan, at least not on the testbench.
X1950PRO 3dmark 2000
X1950PRO 3dmark 2001
X1950PRO 3dmark 2003
The old P4 is keeping up with newer video cards better than I would have thought.
Reply 9 of 25, by GeorgeMan
It's useless from one point and on to bench 3dmark2001SE for 3d performance, as the score increases more from CPU overclock 😜
On the other side, 3dmark03 is MORE GPU dependant than most real world games, so it also doesn't show the reality.
Try some real world games...
I will not forget the time Colin McRae Dirt v1.0 came out.
At that time, I had an Athlon64 3500+ w/ X1800XT. It was playable (~25fps) at the LOWEST possible settings @ 800x600! I eventually changed CPU/VGA/Mobo/RAM set for this game, and one month later came out the v1.1 patch which greatly improved frame rate... Damn u Codemasters xD
Reply 10 of 25, by Skyscraper
I use NFS Underground 2 as my game test.
I dont have time to test all cards with more than one game 😁
But the X1950PRO is the card that has been on the test bench the last couple of days when I have been playing games instead of running benchmarks 😀 . It can run every game I try with max settings @ 1024*768. (without the fan connected 😜 )
But that would probaby also be true for the X800PRO. I will switch back to that card when I am done testing the Nvidia cards since this was the card I had in mind for this rig from the start.
I have two identical X800PRO so it would be great if it was fast enough for everything.
Reply 11 of 25, by GeorgeMan
The fan has some meaning for being there. Better have it connected 😜
Then it's not worth all the rush. Just install any games you want and try them for a couple of minutes on both cards. 😁
Reply 12 of 25, by Skyscraper
I noticed that the fan wasnt connected when I removed the card from the test bench, its connected now.
There are some more things I want to get out of this other than just to decide what card I will use for this box. 😀
Im also checking that all my old AGP DX9 cards are still working. Some of the cards have not been used for a long long time, some cards I have never used before.
That the X800PRO will be the card I end up using with this build is almost for certain since it will make it easy to compare performance with the Barton box I will build later with the other X800PRO.
Im pretty sure though that this is the system I acually will use for playing games since the Barton will have to be clocked to crazy speeds to keep up, or so I believe.
Time..*cough* benchmarks will tell.
Reply 13 of 25, by sliderider
X800/X850 were a tremendous leap from the 9800XT and they handle high levels of AA and AF better than GeForce 6. The only downside is that there are not ATi drivers for Windows 98. GeForce 6 does have driver support for Windows 98.
Reply 14 of 25, by Skyscraper
I have an Abit BH6 Coppermine box with a Gf-3 for Windows 98 games so it will not be an issue.
I am benching the Nvidia cards as I am writing this, the 6800GT is next in line!
I think that card will end up in a Canterwood build.
In the end Im sure that I will have more systems than I will ever use but its better to have systems than componets laying around... everywhere...
Building the first retro boxes made me sort through some of the things I have collected over the years...
When you are the go to person people consult when they need help with upgrades... things tend to accumulate.
Reply 15 of 25, by Gamecollector
As a long time user of ATi Radeon X850 PE Agp and WinME...
1) There is an official Win9x support through the standard Catalyst driver pack. The last version with Win9x support is 6.2.
2) Still the card/drivers are bugged with standard ATi failures. Like a wrong negative blending, a table fog "support" etc...
3) The drivers aren't working with HT=on (freezing), you must disable the hyperthreading in BIOS.
I have used this card in the test PC for the nGlide Win9x compatibility table. Unfortunatedly this card have died from soldering troubles...
Reply 16 of 25, by Skyscraper
Time for some Nvidia Cards
All Nvidia cards will use ForceWare 92.91
The Geforce 5600 Ultra 128 mb
Geforce 5600 Ultra 3dmark 2000 (Ignore GPU-Z reporting the memory running at half speed)
Geforce 5600 Ultra 3dmark 2001
Geforce 5600 Ultra 3dmark 2003
I bet Nvidia wasnt satisfied with the performance of this card.
Reply 17 of 25, by Skyscraper
This card I really like. Its one of the best looking cards ever.
Asus V9950Ultra / Geforce 5900 Ultra 256 mb
Geforce 5900 Ultra 3dmark 2000
Geforce 5900 Ultra 3dmark 2001
Geforce 5900 Ultra 3dmark 2003
DX9 performance could have been better but this card is a good candidate for an overkill windows 98 build.
Reply 18 of 25, by Skyscraper
I used this card for a long time.
I quit my job and moved to another town 2004, then World of Warcraft was released and I kind of played World of Warcraft for a couple of years instead of working or studying.
This card was flashed with a Geforce 6800 Ultra bios and was rendering 3D probably ~12 hours a day for 3 years.
My gaming rig at the time was a s939 Nforce-3 Athlon 64 box that got upgraded with a dual core Opteron.
Now the card wont run at that speed without issues so I flashed it with the original bios. The overclocking adventures is over for this card.
XFX Geforce 6800GT hiding under a NV5 Silencer.
Geforce 6800GT 3dmark 2000
Geforce 6800GT 3dmark 2001
Geforce 6800GT 3dmark 2003
Good performance and a huge step up from the 5900 ultra.
Reply 19 of 25, by Skyscraper
The last card, its not even faster than the 6800gt but its a mid range card from the next generation.
Geforce 7600GS with a custom quiet fan
Geforce 7600GS 3dmark 2000
Geforce 7600GS 3dmark 2001
Geforce 7600GS 3dmark 2003
Not as fast as the 6800GT but overclocking helps
Geforce 7600GS slightly overclocked 3dmark 2003
Another good DX9 AGP card
