First post, by ayumu270
Hello. It's good to see you guys.
I'm newbie from South Korea.
I got these on internet flea market.
I assume, these are from industrial computer system.
I googled with partnumber and etc... for some information. But I couldn't get satisfactory result.
I can't figure out how to connect PSU and how to attach memory modules.
How can I turn these on?
Mobo from convergent technogy. Has 80386DX-25 as a processor.
Large pic :
The attachment DSC_4113.JPG is no longer available
A kind of part number?
Large pic :
The attachment DSC_4114.JPG is no longer available
Pins for connect to PSU?
Large pic :
The attachment DSC_4118.JPG is no longer available
Module for controlling peripheral devices(KBD, FDD, HDD...)
Large pic and some more pics. :
The attachment c1.jpg is no longer available
RS-232C interface, and a scene of putting these togeather.
The attachment c2.jpg is no longer available
Reply 1 of 1, by Old Thrashbarg
That is part of a later generation Convergent NGEN system... sort of a modular multi-user workstation. Here is a picture of what a complete one would look like... of course that's an early model, but the later ones used a similar sort of chassis design.
The power supply is proprietary, and I don't know if you can easily adapt a standard one to work... even if you were able to trace out the pins, I believe they also use some non-standard voltages.
You are also missing the RAM cards, which look like something like this. Again, proprietary.
Basically, getting it going will be difficult at best. If you're intent on it, you could try posting about it over at the Vintage Computer Forum... somebody there might have some of the relevant parts or some more detailed information about it.
