First post, by warney
Hey Guys,
I have used DOSBox to try and emulate this program to no avail =(
What I did was run install.bat, run setup.bat, then try and run heroes.exe, only to be told that it couldnt access the CD drive. I then restarted and mounted the CD Drive of my computer in, and this did not work either.
I am now stuck as to what to do, because I have even gone to the extent of copyin a CD filled with the files, and that doesnt work either....
Any help would be appreciated
Thanks in advance
Reply 1 of 3, by eL_PuSHeR
I am guessing you have already tried all available parameters, haven't you?
mount x x:\ -t cdrom -label <label> -ioctl -usecd 0
ETC....
Reply 2 of 3, by warney
thanks pusher that worked!
now all i have to do is work out how to make the game play faster, i have played with ctrl f7, f8, f11, f12 etc but it is still quite laggy, any ideas?
