Quake Installation Issue
First post, by BeastBad1368
When I tried to install Quake on DOSBox v0.74 I get a message saying 'Drive Error - That drive is not available! Press Enter to continue.' and I've also added a screenshot as prof.
pl8y.jpgUploaded with ImageShack.com
Reply 2 of 4, by BeastBad1368
SKARDAVNELNATE wrote:
See this thread:
60 seconds guide to getting your game to run in DOSBox
If you need more help post all the commands used prior to reaching that screen and the responses given by DOSBox.
Could you help me on what I looking for because you didn't say with one I should look for.
Reply 3 of 4, by SKARDAVNELNATE
Reading comprehension = False
Let's try it this way. On my computer I have the folder path C:\DOS\GAMES
In DOSBox I type MOUNT C C:\DOS\GAMES -t dir -freesize 400
DOSBox responds Drive C is mounted as local directory C:\DOS\GAMES\
My optical drive is D:\
In DOSBox I type MOUNT D D:\ -t cdrom
DOSBox responds Drive D is mounted as CDRom D:\
Next I type
D:
INSTALL
and go through the setup program.
Now you tell me what you did.
Reply 4 of 4, by BeastBad1368
Thank you for giving me on what I need to do.
