First post, by baerenwurm
There are just some (distorted) lines with "Box Shell v0.60" and the Windows XP OS loading bar below. I tried the "vgafix.exe", but it didn't work.
Any idea?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
did you remove all icons in the systembar which aren't needed.
especially things of videocards are bad
Water flows down the stream
Reply 2 of 2, by baerenwurm
Just noticed that it works if I use a lower refresh rate (60 Hz)
