First post, by DavidC
Some of my game require a higher cycles or frameskip, so I have tried to set up a configfile to automatically change these settings, but I cannot get it to work. What EXACTLY is the procedure for setting up a configfile. What am I doing wrong?
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
you're providing very little information on what you tried. so I'll start very basic
start dosbox
in dosbox:
config -writeconf c:\dosbox.txt
exit
in windows:
double click on c:\dosbox.txt
change what you like
runs dosbox like
dosbox -conf c:\dosbox.txt
Water flows down the stream
Reply 2 of 6, by Guest
Thanks. That seems to work. The Readme file did not say that I had to specify the directory or make it a txt file.
Reply 3 of 6, by Guest
P.S. I hope this isn't too off topic, but how long does it take to register? I registered last week and still can't log in to get help with some specific games.
Reply 4 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
You should have gotten an activation email.
Reply 5 of 6, by Guest
No, I never did (unless the subject line was "free Viagra" or something like that). When I try to log on, it says that my account is innactive and if I try to register a second time, it says my e-mail is already taken.
Reply 6 of 6, by War_Tourist
Try using a real email address?
