New PSUs are installed and running 😀
I almost thought the 430W one was DOA... After installing it, windows started spitting out a lot of errors and bluescreens, including one I've never seen before. Turned out the BIOS settings were reset and defaulted to CAS 2.5... Setting it back to 3 fixed it.
Some ripple measurements from the 380W version:
- Switched on manually, nothing attached:
5V: 250mV
12V: 125mV
- Installed, switched on:
5V: 55mV
12V: 70mV
Not exactly the 20-25mV I've seen on reviews, but then most of this is somewhere in the MHz range which USB scopes (used by all PC hardware reviewers) don't pick up. And the caps on this mainboard are like, 15 year old Chinese crap.
- Harddrives switched off through APM:
5V: 50mVpp
12V: 55mVpp
Major noise source here. After switching these off most of the audio-frequency noise is gone.
Just for kicks, try this: turn up your speakers to eleven, and run a speedsys HDD test 😉
nforce4max wrote:jwt27 wrote:
My 7800GS card in the P4 system does require 21A at 12V, or so the manual says... The 430W Seasonic offers 17A per rail (there's 2 of them). Will I run into trouble if I connect the graphics card on one rail, and everything else on the other?
edit: it seems the S12II has only one solid cap, one Rubycon and the others are Chemi-con. And only one 12V rail instead of two. I assume this rail can deliver 34A then. The 21A rating for the 7800GS seems a little optimistic anyway... that's 254 watt for just an AGP card!
I really wise that people wouldn't quote min psu requirement for a single graphics card in that matter especially Nvidia as it is not accurate except for a whole system when the card barely needs more than 5 or 6 amps to run full load. That card and a P4 don't use that much at full until one starts overclocking the cpu, the graphics card won't top much beyond 105w max if even 90w. So don't quote amps like that unless it is whole system or go by what will actually be needed. There is a small period when the system is first started where the loads are higher but that is in milliseconds.
They probably calculated the amp rating for a complete system on full load, with some safety margins. I looked up the 7800GS's TDP and it's "only" 75W. I think the 380W model would have been sufficient for the whole system.
