First post, by ehdium
Hello,
I'd like to send keystrokes into a dosbox window.
I'm using AutoIt3 to run a script like this:
ControlSend("DOSBox 0.74,","",0x00080210,"W")
with no success. So I ask: have you had success in sending keystrokes to a DOSBox window? If so, how?
Thanks.
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Something like that should work, not sure if what you did does, though. You could look for emendelson's (search the users posts here) copy/paste thing for Windows. I think he uses autoit as well.
At first glance I'd say though that it should reference dosbox.exe rather than "Dosbox 0.74"
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by emendelson
Just use Send, not ControlSend. Something like this works well:
If WinActive("DOSBox") Then
Send("{TAB}")
EndIf
You'll need to use WinActivate("DOSBox") before running that code.
