First post, by GonzoML
Is there a way for DOSBox to indicate less bytes available on a drive?
AutoCAD 9 runs fine in DOSBox, but when saving the file, it returns an error saying "not enough space on disk" (because the "bytes available" is too large).
I've been using AutoCAD 9 continuously for >25 years, almost all of the time on OS/2 in DOS sessions -- works great! About 10 years ago when I started running OS/2 on a Pentium II with huge hard disks I had the same above error, but I solved the problem by creating a small logical drive with less than (about) 100Mb available, and then AutoCAD 9 would save the files to that small logical drive just fine. On my OS/2 machine, it doesn't matter how large the logical drive is, but rather it's all about the "bytes available" on that logical drive that matters -- AutoCAD 9 can't properly interpret if there's enough space on the drive unless the "bytes available" is under some magic number (about 100 Mb as I recall).
I don't see where DOSBox supports virtual disks.
Any ideas?
Thanks.
Reply 1 of 5, by Joey_sw
GonzoML wrote:
Is there a way for DOSBox to indicate less bytes available on a drive? […]
Any ideas?
Thanks.
DosBox primarly designed for games ...,
there no support for non-games program.
And from your post, i see you haven't read/understood the readme files that included in DosBox, read that first.
-fffuuu
Reply 2 of 5, by GonzoML
Although I looked for help in lots of places, I now found the README.txt, and yes I understand how to set freesize. No luck yet resolving AutoCAD 9 error message. If I figure it out on my own, I'll check back here to see if anyone cares to hear what I accomplish. Otherwise, I won't bother you again.
Reply 4 of 5, by GonzoML
mount a c:\dosprog -t floppy -freesize 5000 <--- solves problem, even with this large amount
mount c c:\dosprog -freesize 5 <---- does NOT solve the problem
Seems AutoCAD9 understands the floppy in DOSBox better than other.
Reply 5 of 5, by Jorpho
If I'm not mistaken (see for instance Terminator (1990) install help ), "-t floppy" sets the total drive capacity and not just the free capacity. This in turn suggests that you could substitute an appropriate "-size" parameter for "-t floppy" and satisfy AutoCAD, but as per the readme, the "-size" parameter, unlike "-freesize", requires a specification in terms of cylinders, heads, and sectors. And if "-t floppy" works for you, there's no reason not to stick with it, I guess.
