First post, by Napivo
First let me congratulate you guys for writing this excellent program, before I start telling you what I can't do :=)
Well this is my problem. I wondered if dosbox could run fractint. Much to my surprise it does and even can get color cycling working at high resolutions but whenever I switch out between the text and graphics mode somewhere on the 51 line the image gets corrupted.
Can this be solved / worked around.
these are the versions I am using
DosBox v0.74
Dfend 1.3.5
and the latest version of Fractint 13 February 2012 - Fractint 20.04p12
Anyone have any idea what goes wrong?
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The glitched line in VESA modes is fixed in SVN, so you could try using an SVN build.
The low-res VGA and register-tweaked VGA modes show more significant corruption of the graphics when returning to graphics mode from text mode. I have a workaround program for the issue, but there's no need to bother with it if those modes are of no interest.
Reply 2 of 3, by P4R4D0X
Yes this is a known bug... I made a post a while back but there are workarounds. Just change your machine type to svga_et3000 or svga_et4000 and it will work properly. It has been tested by me. As far as I know this bug might be hard to fix...
You will find the post here: FRACTINT graphics corruption
Reply 3 of 3, by Napivo
Oh my.... This actually works and solved my problem
I Downloaded the version from (first one I tried) http://ykhwong.x-y.net/
It is capable of running Fractint without a glitch.... Thank you so very much.
(jumping up and down)
I an going to be happy for days 😀
