First post, by tfabris
When I run DosBox, I either let it run with a base configuration I've carefully specified in dosbox.conf, or I add "-conf myfile" so that it will pick up whatever settings are in "myfile".
So far, "myfile" is a complete copy of dosbox.conf with specific changes made to existing lines.
What if I did this... What if "myfile" contained ONLY the edited lines?
Would it pick up all the base settings in dosbox.conf, and then add only the changes from "myfile"?
The idea is that I could have a base set of configurations (not the program defaults, but my *specific* base configurations) in dosbox.conf, and then I could put ONLY "dpmi=true" or "cycles=2500" or some such in the specific configuration files for individual games that needed it.
If dosBox did this, that would be really cool. Any chance it does this already?
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
yeps only the changes are fine
as long they are placed in the proper [section]
so
[dos]
ems=false
is a valid configfile
Water flows down the stream
Reply 2 of 7, by tfabris
Cool, thanks!
Reply 3 of 7, by tfabris
I just tried this, and it does not work.
It picks up the settings in my alternate config file, but it ignores any settings I've specified in dosbox.conf. It simply runs the program defaults plus the alternate config file. That's not what I was asking: I was asking if it would use dosbox.conf plus the alternate config file.
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
short anser no.
it uses only the file specified at commandline by -conf.
if none given it looks in the current directory for dosbox.conf
next version
none found parse
windows $HOME/dosbox.conf
linux $HOME/.dosboxrc
MACOSX some long ....
Reply 6 of 7, by XulChris
Qbix wrote:
short anser no. it uses only the file specified at commandline by -conf. if none given it looks in the current directory for dos […]
short anser no.
next version
none found parse
may i suggest for linux:
first check /etc/dosbox.conf
next check $HOME/.dosboxrc
the config file in $HOME should override the one in /etc/ if it's found.
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
Anonymous wrote:
Then why did you say "yes" to my first message?
as you stated yourself. I misunderstood your message.
