First post, by MusicallyInspired
- Oldbie
So I've been trying to get SQ5 to work with the Tandy 3-voice driver. This has proven difficult. I'm not even 100% sure if the Tandy driver was bundled with the game, but if it wasn't I got it from another SCI1.1 game that DID support Tandy 3V. My problem is that EGA640.DRV does not work when DOSBox is set to machine mode Tandy. I can start up the game but get no graphics, however I do hear the Sierra fanfare in 3-voice. After that, nothing. I don't know if this is because the game hangs after the opening screen and no longer responds or if the soundtrack is actually not compatible with Tandy 3V outside of the Sierra fanfare (which was probably the same resource file used for all the other SCI1.1 games, some of which did support Tandy 3v.
My other solution was to set machine mode to VGA or SVGA and just turn Tandy sound on. This works for AGI games and for SCI0 games, but strangely it does not work for SCI1.1 games. When running the install program it marks Tandy 3V as incompatible with the system (whereas it is compatible when running DOSBox in machine mode Tandy). The game launches but is completely silent if I use it anyway. And I know that means it's not functioning properly because I can hear the Sierra fanfare (at least) when running under machine mode Tandy.
I'm frustratingly curious as to whether SQ5's soundtrack is actually Tandy compatible or not. I suppose I could just check it out with SCI Resource Viewer, but that still leaves this issue of why Tandy 3V doesn't always work when setting Tandy=on in dosbox.conf. Or why EGA640 doesn't work in machine mode Tandy. I guess the latter is just because it was made for EGA cards and not the Tandy as I had previously thought. Was there ever a Tandy-compatible EGA driver for SCI1.1 games does anybody know? It seems odd that they'd supply Tandy 3V drivers with SCI1.1 games if they didn't have a compatible graphics driver to go with it.
Yamaha FB-01/IMFC SCI tools thread
My Github
Roland SC-55 Music Packs - Duke Nukem 3D, Doom, and more.
